24/192 DAC für den Raspberry Pi
#41
Hello!
This piece of text is for non german readers. That contains a short story about my DIY HifiBerryAmp.
Please excuse my weak EnglishSad
A little bit of history. I started with DIY HiFi last year with building a cabinet for a loudspeaker set called Micro 2006
You can see this loudspeakers on the picture below.
[Bild: HiFiRaspiAmp3.jpg]
Please take a closer look to the picture, to the left bottom corner. You can see, that I don't have space for an big amp. Another importent thing is, that there is not enough space for the hot air from an traditional amp.
Second reason for building an amp with HifiBerry and Raspberry Pi was, that I like to read books while I'm listening to backround music (somthing like watching a movie in my mind - that need a soundtrack). I don't like to power my PC only for little bit if background music and it was not really comfortable to having the noise from PC in background.
So I was looking for an small network music player with the ability of playing FLAC files. I found some good commercial products, but they are too expensive.
I found here in this thread a part of the story of developing HiFiBerry DAC. This was in my mind very suitable for my project, because it is small and it don't need an own power supply.
For Raspberry I choose Volumio distribution, because it cames with built in support of HiFiBerry DAC. Another reason for using Volumio is, that I don't need an App to use it from smartphone, iPad or PC.
The amp is build with two switching power supply from Meanwell (a 200W 24V for amp and 15W 5V for Raspberry). The amp module is from HifiMeDiy and I really like it.
I'm very satisfied with the HiFiBerry DAC, I was in the beginning really surprised how much sound I get from this cheap DAC. It is amazing for looking in the faces of friends, after I told them how much HiFiBerry costs. They newer minded that this sound is possible with so few electronic parts.
Thanks to the HiFiBerry crew for this outstanding DAC!
Greetz
Otto Normahl
Hiho,
ich habe mir ja auch den Hifiberry gegönnt und bin sehr zufrieden. Als Basis funktioniert Volumio ganz gut, aber ich bin gerade dabei das 2,8"-Display von Texy obendrauf zu montieren, damit ich eine direkte Bedienmöglichkeit habe. Erst Erfolge sind schon zu verzeichnen...ich kann Titel auswählen und abspielen, aber leider fehlt noch die Interaktion zwischen dem Webinterface und der Python-Oberfläche. Naja, ist ja ein Hobby...Big Grin
Nochmal Danke an Daniel für den Hifiberry :w00t:
Grüßle Sven
Hört "And I raise my head and stare into the eyes of a stranger" mit seinen DOBs
bAD kARMA schrieb:Als Basis funktioniert Volumio ganz gut, aber ich bin gerade dabei das 2,8"-Display von Texy obendrauf zu montieren, damit ich eine direkte Bedienmöglichkeit habe. Erst Erfolge sind schon zu verzeichnen...ich kann Titel auswählen und abspielen, aber leider fehlt noch die Interaktion zwischen dem Webinterface und der Python-Oberfläche.
Sehr cool. Gibt es davon Fotos?
Von meiner Testversion nicht, aber der User BBUK hat ein Video von seinem RPI mit BPodTouch hochgeladen. An dem Code "lerne" ich gerade. Sowie an noch ein paar Bedienoberflächen. Geht aber nur sehr schleppend voran.
Im Prinzip sieht es bei mir genauso aus, nur dass bei mir noch ein Hifiberry zwischen dem RPi und dem Display steckt.
http://www.youtube.com/watch?v=X0d7d0fCjEI
Grüßle Sven
habe jetzt auch einen Pi mit Volumio. Aus einem zweiten habe ich mir nach dieser Anleitung http://www.welzels.de/blog/projekte/rasp...pberry-pi/ einen NAS mit SAMBA und Minidlna aufgebaut. Habe es mittlerweile auch geschafft, den NAS im WEB UI einzubinden. Allerdings finde ich keine Dateien auf dem NAS, obwohl was drauf ist.
Wenn ich unter Ubuntu in den Netzwerken surfe, kann ich aber unter dem Volumio Verzeichnis den NAS finden und auch auf die Dateien zugreifen.
Hat jemand evtl ähnliche Problem beim konfigurieren gehabt ?
Gruß, Martin
