Hmm, jetzt fangen die Schwierigkeiten doch an. Ich habe das ganze auf 8 Kanäle erweitert.
Code:
## DEFAULT GENERAL SETTINGS ##
float_bits: 64; # internal floating point precision
sampling_rate: 48000; # sampling rate in Hz of audio interfaces
filter_length: 8192,16; # length of filters
overflow_warnings: true; # echo warnings to stderr if overflow occurs
show_progress: true; # echo filtering progress to stderr
max_dither_table_size: 0; # maximum size in bytes of precalculated dither
allow_poll_mode: false; # allow use of input poll mode
modules_path: "."; # extra path where to find BruteFIR modules
monitor_rate: false; # monitor sample rate
powersave: false; # pause filtering when input is zero
lock_memory: true; # try to lock memory if realtime prio is set
## LOGIC ##
logic: "cli" { port: 3000; };
## INPUT, OUTPUT ##
input "left", "right" {
device: "jack" { ports: "alsa_pcm:capture_1", "alsa_pcm:capture_2";};
sample: "AUTO";
channels: 2/0,1;
output "lsub", "llow", "lmid", "lhigh", "rsub", "rlow", "rmid", "rhigh" {
device: "jack" { ports: "alsa_pcm:playback_1", "alsa_pcm:playback_2", "alsa_pcm:playback_7", "alsa_pcm:playback_8",
"alsa_pcm:playback_3", "alsa_pcm:playback_4", "alsa_pcm:playback_5", "alsa_pcm:playback_6";
sample: "AUTO";
channels: 8/0,1,2,3,4,5,6,7;
delay: 0,0,0,0,0,0,0,0;
coeff "subleft" {
filename: "XOSubL48.pcm";
format: "FLOAT_LE";
coeff "lowleft" {
filename: "XOLowL48.pcm";
format: "FLOAT_LE";
coeff "midleft" {
filename: "XOMidL48.pcm";
format: "FLOAT_LE";
coeff "highleft" {
filename: "XOHighL48.pcm";
format: "FLOAT_LE";
filter "ls" {
inputs: "left";
to_outputs: "lsub";
coeff: "subleft";
filter "ll" {
inputs: "left";
to_outputs: "llow";
coeff: "lowleft";
filter "lm" {
inputs: "left";
to_outputs: "lmid";
coeff: "midleft";
filter "lh" {
inputs: "left";
to_outputs: "lhigh"/1;
coeff: "highleft";
Und nun habe ich das seltsame Phänomen, dass der Mitteltöner dem Hochtöner hinterherläuft. Die Verzögerung ist gut hörbar und dürfte deutlich über 100ms betragen.
Dummerweise kann ich mir nicht erklären, woher die kommt. Ich hatte die 4-Wege-Filter in Verdacht, aber selbst wenn ich die bisherigen 2-Wege-Filter nehme, passiert das. An denen liegt es also nicht.
Irgendwelche Ideen?
Ich hatte bisher noch nichts mit BruteFIR zu tun aber vielleicht braucht er länger um tieferfrequente Sachen zu filtern.
Schonmal versucht mittels Messsystem den genauen Versatz festzustellen und mit einem delay zu korrigieren?
I'm not insane... my mother had me tested - Sheldon Cooper
Die Filterlänge ist ja eigentlich 16*8192 für alle Filter.
Versuch doch mal Sub und MIDLOW jeweils auf rechts und links von dem selben Subdevice zu legen.
Vielleicht hinkt ja nur der DAC hinterher.
Ändert sich was wenn du das output plugin auf alsa umstellst?
Zwangsfalter
100 ms Nachhinken wäre schon der Hammer wenn es soviel wäre.
Eventuell handelt es sich aber um ein psychoakustisches Phänomen, da der Hochtöner und der MT nicht den richtigen Pegel haben; da hab ich mir grad mal auf der bpa Seite die Messung vom Coax angesehen.
Du senkst den Pegel des Hochtöners nur um 1 db ab, wenn ich das beim überfliegen richtig gesehen habe.
Um diesen Effekt aus zu schließen hilft nur Messen wie groß der Zeitversatz tatsächlich ist, das einer vorhanden ist, ist unstrittig.
Nach der Messung dann Pegel und Delay anpassen.
Wenn ich deine Konfiguration richtig im Kopf habe, möchtest Du eine Blackbox betreiben, das heißt Du gibst ein Signal von aussen in deinen Faltrechner.
In diesem Fall ist die Benutzung von Jack nicht notwendig, auch auf das Sound-Loopback-Device würd ich verzichten...
Elmar
La vida es no ponyhof
Das Problem habe ich mit mid/high und die laufen auf dem gleichen DAC. Selbst wenn ich die auf die Kanäle 0/1 lege, habe ich das Problem. Es scheint aufzutreten, wenn ich die Konfiguration von 2 auf 8 Kanäle erweitere.
Noch nicht probiert.
Das wäre die am wenigsten wünschenswerte Lösung. Ich vermute noch irgendwo ein Konfigurationsfehler (vielleicht nicht direkt bei BruteFIR, sondern bei der Systemkonfiguration oder bei JackD), der hierfür verantwortlich ist. Ich möchte erstmal versuchen, den zu finden.
Zwangsfalter
An dieser Stelle habe ich nun ein Verständnisproblem.
Der riesengroße Vorteil von Brutefir ist doch, dass man Laufzeitunterschiede , egal wodurch sie bedingt sind, einfach ausgleichen kann.
Auch der Pegelunterschied ist zwingend anzugleichen, sonst gibt es nie eine klingende Box.
Um das Messen kommst Du also auf keinen Fall drum herum.
Desweiteren würde ich linke und rechte Ausgänge immer auf einen Soundkartenausgang legen, also beide Subs auf 0/1 beide Lows auf 2/3 usw..
Die Konfig würde ich auch mal so umschreiben, dass auch alle 8 Ausgänge arbeiten müssen.
Elmar
Nun, da haben wir wohl wirklich ein unterschiedliches Verständnis. Ich setzte Brutefir nicht ein, um Software- oder Konfigurationsfehler durch zusätzliche Delays zu umschiffen. Eine Signallaufzeit über 100ms ist für mich generell zu viel.
Dass gemessen und die Pegel angepasst werden müssen ist natürlich klar.
Die gleichen Kanäle auf den gleichen DAC zu legen, ist sicher sinnvoll, dafür brauche ich dann aber erst noch Adapterkabel. Aber das ist dann eh "Feintuning".
Zwangsfalter
So, heute komme ich mal wieder dazu, etwas zu testen. Die Umstellung als ALSA ändert nichts.
Ich habe mal versucht, den zeitlichen Versatz zu messen. Es sieht so aus, als sei der eine Filterlänge. Bei mir sind das im Moment 65536 Taps, also so 1,2 Sekunden bei 48kHz. Wenn ich die Samplerate auf 96kHz erhöhe, sinkt der Versatz auf die Hälfte.
Irgendwo ist da also noch ein Fehler bei Brutefir. Hat jemand sonst noch eine Idee?
Zwangsfalter
Über 2 GB ohne ein grafische Benutzer Oberfläche ist schon heftig.
Meine Version mit Ubuntu 10.04 und LXDE als Oberfläche hatte glaube ich installiert 1,5 GB verbraucht. (CD Iso war so knapp unter 400MB)
Kannst Du Brutefir in einer Konsole starten und die Meldungen posten?
Elmar
Den Fehler bei Brutefir habe ich vermutlich gefunden. Ich habe da ein kleineres Durcheinander von minimal- und linearphasigen Filtern veranstaltet (sieht zumindest so aus).
Jetzt wird aber erstmal neu installiert.
Wenn, wie im Beispielbild gezeigt, das linearphasige Filter 871 taps hat, dann müssen für eine richtige Messauswertung mindestens 435 Samples links vom Pulspeak vorhanden sein. Vermutlich entstehen die -30 dB schlichtweg durch Abschneiden von Samples vor dem Puls.
Zumeist wird die Bedeutung von Samples mit kleiner Amplitude eben wegen der geringen Amplitude gewaltig unterschätzt.
Viele Grüsse
Uli Brüggemann
AudioVero e.K., www.audiovero.de
Gewerblicher Teilnehmer
_________________________________
... und die gute Fee erfüllte den sehnlichsten Wunsch des Basstreibers, nämlich ein verdammt schneller Bass zu sein. Er spielt jetzt als Hochtöner
Vielen Dank! Da ich mit Arta nur 300 samples Vorlauf bekomme werde ich mal einen Test mit 600 Taps veranstalten um dem Phänomen nach zu gehen.
EDIT:
@Uli: Ein schneller Test bestätigt deine Vermutung! Erschwerend kam allerdings hinzu, dass ich wie gewohnt den Cursor sogar noch bei sample 300 als Startwert stehen hatte. Sonst schafft es die Hochpassflanke bei gleichem Filter auch fast ganz runter. Die Phase wird nun auch "richtiger" dargestellt. Das hatte vorher übergaupt nicht gestimmt wie ich jetzt im Vergleich feststellen musste
Geändert von slacky (18.10.2011 um 15:00 Uhr)
Slacky was für Filter Design Programm hast du da?
Das Toolbar sieht schwer nach Wine aus.
Sebastian
Siehe Post #19. Das ist das Filter Design and Analysis Tool aus der Signal Processing Toolbox für Matlab
Danke
Ich werde mit die Demo mal bei Zeiten zu Gemüt führen.
So, mein Brutefir setup läuft mal. Auf dem neuen Memorystick ist auch noch genügend Platz :-)
Jetzt habe ich aber wieder ein Problemchen mit dem Timing. Die beiden Bandpässe in meinem 4-Wege-Setup haben jetzt wieder einen (kleineren) zeitlichen Versatz zum Hoch- und Tiefpass.
Die Filter sind mit Maxo generiert (8. Ordnung) und sind linearphasig. Ich hab es auch nochmal angeschaut und es sind auch wirklich linearphasige Filter, der Impuls sitzt bei allen Filtern genau in der Mitte.
Ich habe den Eindruck, dass das irgendwie mit dem Bandpass zu tun hat, im Moment weiss ich aber noch nicht, wo mein Denkfehler ist.
Ähnliche Themen
Von Wen im Forum Weichenfragen
Antworten: 8
Letzter Beitrag: 31.05.2012, 20:31
Von usul im Forum Weichenfragen
Antworten: 15
Letzter Beitrag: 04.09.2011, 15:45
Von ferryman im Forum Allgemeine Themen
Antworten: 163
Letzter Beitrag: 27.04.2011, 18:51
Von Sleepwalker im Forum Weichenfragen
Antworten: 25
Letzter Beitrag: 08.04.2011, 22:51
